swapping eingines
question is ,i am changing engines out of an older m and installing 264ci out of 450 can i swap flywheels without throughing motor out of balance .the 248ci has a little diff flywheel ,heavier i think but looks like it will bolt on
Hi Danny, a 450 has the C281 engine. If you've got a C264, it may have come from a 400 or Super M.
The M's flywheel should fit just fine. Other than minor internal revisions, the C248-C281 4-cylinder engines are all the same design, use the same bolt patterns, etc.. Eli Whitney's interchangeable parts system at its finest :)
