swather pump output
It looks like the 1214 uses the same drive motor as the Hesston swathers - an Eaton 5 cubic inch. If so, and assuming the motor is running about the same speed, the output of the pump would be around 26 gpm at at max of 4000 psi.
Keep in mind the assumption I'm making here about the speed at which your motor runs. I do know that your motor displacement is 5 cubic inch so if you can find out what the true motor speed needs to be for that model you would take RPM times 5 divided by 231 to get the required flow rate. The Hesston models, which I'm more familiar with, run at about 1200 rpm motor speed.
