Hobo,NC
- Location
- Sanford, NC
(quoted from post at 06:51:55 11/02/23)(quoted from post at 13:22:50 11/01/23)
If that switch could tote a 30 amp circuit the blade push on connection won't. Even the one Geo posted the heat build up on the blade connection at the relay will come back to haunt ya.
This is a case the load needs to be hard wired no push on connections on the load side.
Why you don't play with this its not like the heater blower motor quits blowing, this can and will destroy the engine.
That switch would ground the relay which would provide power to the fan.
Very little current would be going through that switch.
Just about every car or truck produced today energizes the cooling fans via the properly rated relays.
This post was edited by Brown David on 11/01/2023 at 05:55 pm.
I know that, a poster stated to run it directly off the switch to eliminate the relay and such... This is not my first rodeo.
