I tore the transmission on my JD 2010 down, almost 100% certain the issue was a stripped shift collar. After all that work, all I found out was that I was wrong. The only part that I know 100% is bad is the High Range Syncronizer Blocker. It is missing all of the balls that are supposed to hold it in the detent on the tranny.
Could that be the reason my transmission will not go in 5th or 6th but will go in all the rest of the gears? I don't think so, but I don't know what else to look at while it is apart.
For all of the dialog on this issue, you can read the 2010 Synchro-Range Issues Post.
Thanks
Thanks
