Synthetic Oil
Denny 5
This is perhaps a topic that has been beaten to death before. I did a search on it and only had a few results.
My question is, can I use synthetic oil in a older tractor that has seen nothing but conventional oil all its life. Say like a JD 2440 diesel? I sure would like to use the 0-40 to make it easier starting in the winter here in Wisconsin.
Have any of you done this? Any thoughts....?
Did it with several older Deere's and a couple of other tractors with no problems. I use Deere's plus 50 0W40. Also use it in a plastic Chevy with the secondary Cat removed.
run a hd diesel oil designed for heavy duty work as it is designed perfectly for your application.
You can get these oils in 15w-40 and 5w-40 at any truck stop, auto parts and walmarts...
you can buy chevron delo, shell rotella or mobil delvac oils.
These oils are formulated with extra wear additives to fight wear, extra base additives to fight acid build up from moisture and combustion by products, extra extreame wear and heat additives with moly and zinc, that regular oils do not have. They are designed for soot suspension to keep the engines clean for longer oil change intervals... The recommended change interval is 10,000 miles in a heavy duty applications. If your starting in very very cold weather, then get the 5w-40.. if you not plowing snow at minus 30, then the 15w-40 will do fine for most of us.
HD oils due to the additives will start to clean the engine of sludge and varnish build ups.. so if you gaskets a hard and cracked, you can see increase weeping or small leaks as years of sludge is removed and the bad gaskets are now exposed.
So.. good news is that there are lots of great hd motor oils out there for your tractor that will work great!!!
I used the AMSOIL in a slant six Plymouth. It started using oil so my mechanic put valve seals into it. When it was done, he asked me if I ever changed oil in it? I told him I had Amsoil in it and had about 20,000 miles on it. Well, he said it has GOT to be the dirtiest motor I've ever had open. I went home, drained it, and never used it again. And, yes, I had changed filters twice in between.
Synthetic oil is for extreme conditions. High heat, deep cold, screaming rpms, turbos and short trip equipment. Cold starts and the running until oil pressure builds is what wears engines.
