T-340 problem
Paul Wald
My T-340 is about to confound me! When I stop, start, or hit a bump, it sputters and tries to die. I thought is was electrical, but if I feather the throttle, I can keep it sputtering for a while. Took off gas tank and cleaned. Replaced short stretch of old rubber fuel line. Would a stuck float cause the sputter (maybe flooding) when bouncing?
Salt Creek Life
You should remove the fitting on the carburetor where your gas line connects and look for a screen that may be plugged with dirt or rust or both. If it isn't plugged your carburetor probably needs to be soaked in carburetor cleaner and all jets blown out with compressed air. If that carburetor has an adjustable main jet it probably needs to be opened a few turns.
Hal
Yeah, I looked there first. No screen or filter. Carb is gonna have to come apart. I see replacement carbs, but may be quite a search for a kit. No sense in breakin it in half without the gasket! I will try to pull it tomorrow and get some numbers to search by.
