nope,
but you only have to split it like you would a clutch, you dont have to remove the whole center section. then you pull a shaft out the front of the bell housing, pull the clutch and ta rods out the side and you are pretty much where you need to be. but sometime the through shaft is stuck in the ta coupler, i had to use a porta power to remove mine.
