Mogster
I have my friends T0-30.the starter is a little rough. I need a set of brushes for it. The tractor was changed over to 12 volts some time ago.
If you are just looking for brushes, this is a forum section, not a catalog area. You might try the column at left and click on tractor parts. Or go to one of the many good catalogs such as Steiner or Stevens. Automotive and industrial electrical repair shops also have the brushes you need and will overhaul the entire starter for you if you wish. The original 6 volt starters will work on 12 volts as long as you don't grind on them too much.
