Hello I was planning to use a replacement manifold off of a F20 on my T20 but I wonder if they are the same? Manifold that is on the T20 now is older
with the brass side draft carb. I am wanting to switch to a newer manifold so that I can use the K5 carburetor. T20 has had plenty of modifications and
no longer has a fuel pump. Throttle linkage on the T20 is on the carb side and the F20 is on the right side. Has anyone used one of the replacement
manifolds on a T20? Thanks, Mike
