t6 fuel issue
farmerfloyd
i've got a t6 i just traded around for and so far so good. got some rusty tracks i'm working on. my question is about fuel i think. what is happening is you start it up and let it idle it will run o.k. for a few minutes. then it will start to spit and sputter and smoke. if i turn the fuel pump off it will level out. of course i have to turn the pump back on or it will die from no fuel. then after it runs a few minutes with the fuel pump it happens again. if i trottle it up its fine. it may be a bad float or a valve i don't know. anyone got any ideas. thanks
could be a combination of a few things...float or needle and seat or fuel pump is calibrated at too high a pressure and overcomes float pressure...it may take a fuel pressure regulator to completely fix problem or go back to a mechanical pump.
