T6 IH crawler tractor
joeysmith
So I have another project.
Yea me. Maybe!!
My question is how many of the t6 parts are interchangeable with the M?
Especially engine parts. She's weak and needs rebuilding.
(quoted from post at 16:42:45 01/15/21) So I have another project.
Yea me. Maybe!!
(quoted from post at 18:22:19 01/15/21) Joey, whats that T-6 got for attachment, like a Dozer or a Loader ?
Originally it was just a straight tractor.
Just a drawbar no pto or anything
Someone built a blade for it at one time so now it's a dozer I reckon
Help me get the ole girl back out in the dirt!!
I talked to the YT parts guys and they said they didn't know what parts are interchangeable.
They showed parts for the T6 but they didn't know when they would be able to get them.
Was hoping I could order the rite M kit to fit her.
Needing an inframe kit.
yt is just a parts re distributer they sell the same cheap junk
you can buy anywhere on the world wide spider web they
have no or very limited knowledge about any of the parts they
actually resell
It is the same basic engine as the M or W6 tractor. What parts u referring
to? There is some minor differences.
The tracks and rollers have been welded up some time ago.
Rest of the machine seems to be in decent shape.
One steering clutch is stuck but the breaks seem to work.
Didn't have it running for very long.
Well i did dig this much up,For 8,000 ft altitude High compression gasoline,55-425 D
For 5,000 ft altitude High compression gasoline,57-320 D and there is Kerosene and distillate kits available to! These attachments consist of set of four cylinder sleeves, pistons, pins, and rings. I got a TD 6 special attachment book!
(quoted from post at 20:38:24 01/15/21)
Pistons liners rings bngs gaskets and such.
Basically an inframe engine overhaul kit
I think they're pretty much the same engine parts. King of Obsolete on Facebook is a pretty good source of knowledge . You could also join redpower forum. Of course theres lots of good knowledge here.
Well yes it’s the same parts. Nothing hard. Take a tractor engine and
replace it also. It’s just a simple engine. One has tracks one has tires.
Tractractor is what it’s called.
I finally deleted the Kings page a couple of weeks ago. About all he talks about is the "books" he's
writing about his fantasy ladies. Turned into a real waste of the internet.
Yea it's an M engine. You can still source steering clutches and brakes for them too. Almost nothing else is supported. Track and rollers are not supported at all. IH rolled the crawlers into the construction division. Then that was sold out to Dresser which again was sold out to Komatsu. Basically anything that was discontinued before Dresser bought out the construction division was not supported by Komatsu. I'm not sure but I don't think that the IH farm division release the old tractractor rights and they continued to sell parts until IH failed completely. When Tenneco bought out the farm division and merged IH with Case they already had Case construction. No need to support a tractor that ended production more than 2 decades earlier. So no parts other than the engine and steering brake/clutches.
Rick
Thank you.
That's kind of what I was coming up with but wanted a little confirmation before I started ordering parts.
Thanks again!!
The T6, C248, has a different oil pickup system than the M for hillside use. The oil pump is also different and possibly the pan. The T6 also has a fuel pump where as the M does not. Definitely not the same clutch and I would question whether or not the internal trans parts are the same. Most other engine parts should be interchangeable with the M. The starter is also different as the M mounts from the rear and the T6 mounts from the front. Undercarriage NLA
Good luck with your project.
Dennis
He stopped writing those wasted youth stories. But I think he was bored due to nnalert lockdown. Lately he's been making you tube videos using his equipment and his adventures in the frozen North. Mark.
