My understanding is the TAs in the large frame tractors from 706 to the 1586 are run by the hydraulics and are fairly stout. And like the the mechanical TAs on the smaller tractors (656/560) when you use
the TA you shift fast like you mean it - you don't 'ease into gear. My understanding is that replace either is a PIA and requires splitting on the tractor. I know you can run a mechanical TA in the high
side basically for ever even after you have lost the low side. What about a TA on large frame tractor? I thought if the low or high side goes out eventually (usually sooner) the other side will go out and
you have to replace the TA to get the tractor back in the field.
I ask this because my son and I went to an auction to watch a 1066 sell. This tractor had one owner and the guy farmed all of 240 acres with it for its entire life. The tractor looked good - only one
injector was leaking, and the tractor had been under a roof since day one. The tires were good and it fired right up and the cab looked better in 2022 than any of ours did back in 1980. But just before
they started bidding the auctioneer piped up I absolutely guarantee the low side it out on this tractor. When you pull the handle its like you pressed in the clutch but it works fine in high side. My
son was still interested claiming that replacing the TA in that tractor was something he could do winter and we could keep using it this summer without the TA I was not convinced then the tractor sold for
$8500 - which is what I thought might buy it before the TA issues were revealed.
In the thousands of hours we ran the 56. 66 and 86 series tractors we never had a TA fail on a large frame tractor. We had one fail on a 1206 back when I was as kid but dad traded it instead of fixing it
because it was too small for what we doing with it anyway.
How expensive is it for parts for a TA in a large frame tractor and is it just an eventuality for the entire TA to fail after one side fails on a large frame?
