Tach drive gear removal
Mike1959
Hi guys,
I'm trying to remove the tachometer drive located on engine hydraulic pump area under the gas tank on a 611B. Is it a 1 1/16
Nut ? I replaced the cable and it won't move the needle. I'm thinking that the drive gear is stuck or broken. Do I need to take the gas tank off? I'm trying not to. Thanks for any help.
There never ever has been enough room Too comfortably work in that area without removing the tank. Save yourself the aggravation remove it .do the work put the tank back in. You will be better for it in the end. CM
Thanks Chuck. I was hoping for an easy tip/trick . I guy can dream. Lol . At least the tank is almost empty.
Before you go to all the trouble pulling the gas tank, etc, did you check that the tachometer drive is free. The tach is a drag cup movement, the pointer spindle is not mechanically attached to the tachometer drive. If the tach cable core was twisted off, it is more likely the tach drive bearing is frozen from inaction/lack of oil and/or the hour counter gears are rusted. The drive is very fragile so try to spin the brass sleeve on the back with your fingers only, the pointer should jump if the drive is not broken inside the bearing. If the brass sleeve is frozen do not force with wrench, post back we can try to free it up.
Joe
With the tach drive attached to the tractor and with the end that goes to the dash unattached, start the tractor and see if the cable head spins. If it doesn't, push on the end to make sure it is seated. If it does turn, the cable could just be too short. I bought a new cable from our reputable supplier and the cable turned but was not long enough to turn the needle. I rerouted the cable for the shortest possible distance to the tach head and that helped some, but even then it would drop away from the head on occasion and would not spin.
That was on a 351, which has a different cable attachment, but might still be the same problem.
I tried that Ken. It doesn't spin. I have a new/refurbished tach gauge. Do you know if the brass ferrule end goes into the gauge? That is how mine is oriented. I know you can flip it around inside if wrong. I left it the way I got it. One end connector is larger. Also reputable supplier. The cable is longer than the original one. Not sure how far in the cable end goes into the gauge. Since the cable doesn't spin with engine running, I figured it would be the drive gear on engine. The tube the cable end goes into the end on the engine was rusty.
If anyone can offer a suggestion on how to pull the part out of the block ..,
That also might be helpful ..,There is not asingle tach on my tractors built be
CASE working Now ,.. but they are free spinning at the dash ,, so that is a
good sign.
Yes exactly Olgentdc !
That's what I need to know. All the cases I'm familiar with either had working tachs or they gave up on it.
Yes, either the drive gear or the cable not seated in the drive gear. I have a drive for a 351 I would part with but it doesn't look anything like yours. If you have COM it is probably all different.
Yes it is a COM . I was hoping to get it out to see if it can be fixed or cleaned. Turning out to be quite the job to just remove it to check it.
Thanks Ken
If you don't know if the new cable is not turning b/c it may not be seated in the drive, cut off a couple inches of that end of the old cable core and put it in the drive and see if it turns. If you have nothing else jam a small piece of wood in the drive to check if it is turning with the engine.
Joe
