Ericc
I have a 4000 with the tach drive working off of the side of the engine block under the oil filter, the cable inside is the engine is broken, what would be the procedure for replacing this cable. I believe what caused it to break is the tach cable going to the dash was to long and with the bends in it put to much strain on the one inside the engine. Thanks
been a while, but i think the part that cable screws on is retained to block with set screw? whatever, after removal remove broken cable pieces.cable plugs into gear that runs on cam, bends at angle to drive head--simple way of making turn without using a gearbox
there is a small section of cable that fits there. its about 2 inches long, if that long. Be sure to fish out all of the old cable before installing the new piece. The new piece will bend in the groove of the cap that you will have removed to clean out the old. good luck. bill
