TAFE 35DI test drive
I'd like some advice from somebody familiar with TAFE or Massey 35 front suspensions. While test-driving a 1995 TAFE 35DI equipped with an Allied loader, I found that the power steering cylinder (just one on a 35DI, two on a 45DI) joins to the heavy, tapered member which connects the steering box to the front axle. The trouble is that this unnamed part seems to be twisted about 20 degrees off the vertical, not at all the way the same part sits on my Massey Ferguson 35. There's also a bit of pink oil visible at the end of the cylinder, though I didn't see any dripping to the ground.
I'm about to close or reject the deal on this tractor, so some timely advice would come in handy. Is this an easy fix? Is it a deal-breaker? You can find the entire saga of the TAFE 35DI on my blog at
http://rodcroskery.wordpress.com
Thanks,
Rod, finally moved to the farm in Forfar
The Walnut Diary
