Tafe 45di clutch stuck
I own a Tafe 45di which I unfortunately allowed the clutch to stick I believe. I had other repairs I was doing and left it too long. I'm hoping for a bush fix as compared to another repair man bill or splitting it myself. I tried pinning it against some logs and pumping it. I tried towing it backward in gear but tore up the Tundra trying so thats out. I can't appear to find an inspection cover. It's similar to a Massey 240 I believe. I know a miracle won't happen here but any ideas would help. I'm close to out of them
You could try jacking the rear wheels off the ground and securely blocking up. Start tractor in gear with the clutch depressed and stab at the brakes. If you have no way of jacking it up, a less safe option would be to start in gear with the clutch depressed and drive (not into a box canyon or cliff) around stabbing the brakes.
