JimS
I made some tanks skids for fire suppression. One is a round 200 gallon poly and the other an oval 300 gallon poly. I created steel cradles covered in fire hose to prevent chaffing and wear, both tanks held by nylon ratcheted strapping. Both have 2" trash pumps. I made them using old wine barrel racks for expediency and just trying to figure out what I want.
I can wrestle the tanks skids with motor (Without water, obviously) into the back of a pickup by my self by lifting one end and dragging it then jumping out and grabbing the other end and sliding it in. Because I am having to do this fairly often over fire season, I am considering making the frame aluminum for lighter weight and ease of installing/removing. I figure an aluminum frame should be about a quarter of the weight of what I have now.
My question is, as I am unfamiliar with aluminum, is what size square tube or channel should I consider? I figure a couple of hefty rails that run the length and smaller size channel bridging between the rails. What dimension material, what thickness?
Thanks.
Would it be easier to build a frame to set the tanks on, when not in the truck? Then just slide in without all the lifting. Or even build the frame with roller skate wheels, wheels stay with the external frame, not the frame with tank.
My department has a 300 gallon slide in unit commercial made by Danco (I think) and it has 2x2 square tube with 4 cross members in 8' bed length for the skid. All 1/8 wall thickness. Tank in front, pump and reel in back. But two guys can't move it empty, we use a loader tractor if it has to come out of the truck.
(quoted from post at 20:31:34 03/06/21) Would it be easier to build a frame to set the tanks on, when not in the truck? Then just slide in without all the lifting. Or even build the frame with roller skate wheels, wheels stay with the external frame, not the frame with tank.
Yes, a stationery frame, for posts in the ground. Platform level with truck.
But then get two sections of roller conveyor, mount half of each section on platform and other halves in truck.
The tank skid would roll so easily, you could keep a certain amount of water in them while sitting on the racks.
Why not just mount them on a wagon or trailer and pull them where you need them that way and save all the work of loading and unloading? then could mount the pump where it would be handy to get to and use.
Jim, I see that you have only one answer here. Try a shout out to Jonfmn. He does a lot of fabrication with aluminum tubing.
