tapping into TO20 (TE20) hyd for log splitter
BillS TEX
Is it possible to tap a hydraulic line and return on the a TE20? As I look at the drawings other then the pump test ports on the lift cover which my TO20 has and the TE20 does not have the only other ports (plugs) I see on the TE20 are on the bottom of the lift plug unit. They are at a 45 angle, one forward under the right brake pedal and one rearward on the left. I"d like to put a splitter on the TE20.
Are the ports on the Hyd. lift cover only for testing. Can't you use them as a normal hyd.output. What about the port on the bottom of the pump.
