TD-14 Head Torque
thebunns
The torque pattern in the TD-14 service manual is not the correct illustration for head #8064DA on my tractor. It's the right head according to my TC-25-B parts catalog. Can somebody provide me with the correct torque pattern.
Vic[/img:2900c8b507]
I cannot find the manual for that engine but if I was putting the head on I would start off with the bolt nearest the centre and work my way out doing one bolt at a time either side of the centre in an X pattern or would use the pattern I had for a four cylinder diesel, the main reason for the sequence is to tighten down the head uniformly, torque them up three times and you will be ok.
AJ
(quoted from post at 13:51:56 05/06/21) I cannot find the manual for that engine but if I was putting the head on I would start off with the bolt nearest the centre and work my way out doing one bolt at a time either side of the centre in an X pattern or would use the pattern I had for a four cylinder diesel, the main reason for the sequence is to tighten down the head uniformly, torque them up three times and you will be ok.
AJ
I came up with a pattern that does exactly what you suggested but don't know how to post it here.
Vic[/img:3d0c8dd456]
The way to post without repeating the previous post is to clear this text box completely, to post a picture scroll down to the next box, on the bottom you will see choose file, choose the picture you want to post, click on open, now click on preview and the picture should appear under the text like this one I hope, the picture need to be in a format that the board can handle, I use jpg.
AJ
