Td 175b. 407ci
DozinHal
Have a transmission leak that we cannot find. We have taken out the batteries and see oil on the back of the trans on a 3/8 bolt. All I
know for sure is there is a steady drip. We are going to take the battery box out and clean the area. We have not checked the steering
boosters. What bolts are in the back of the trans? We have been all over the front but this is not normal. I really don't know if this is a
traveling leak or what! Thanks
Transmission on that unit is front covered. Nothing to leak at the back except where the transmission sticks into the rear main housing. There if the bolts that hold it in are loose ( three on each side) you would pretty much have a stream under the rear of the unit. The small supply lines to the steering booster are prone to leak.
