TD 6 injection pump
raydawne
I have a early (1940) crawler with a american bosch pump.some one lost the cap off the fitting in the top left corner and screwed in a sparkplug allthou it works it looks dumb.It,s a tee shaped fitting (check valve? ) .the return line fastens to it. if you need a pic I can send one over my phone ray 608 604 9309
If memory serves me right the adapter that screwed into the pump had threads at both ends and a hexagon in the middle,it was a pressure valve,there was a dome shaped nut (cap) on the outside,go to your fuel injection shop they should be able to help,if you can't get the original type an ordinary banjo bolt with a pressure valve in it will do.
AJ
