TD6 no start
I have a TD6 6 cyl direct start diesel . Got no fuel to the injectors . Cranks over good, tries to light with a whiff of starting fluid . Drained tank , fresh fuel . If I crack line at inj pump I have good flow to pump , I cracked return line at top of pump, have fuel there , no bubbles . Throttle lever on side of pump moves ok. Dozer sat for few years but I started it once a year,,this year ,no go . Whats next ??? Even tried some air pressure to the fuel tank .Still nothing at injectors .
Thanks
Have you cracked the lines at the injectors? If you open them up and still have no fuel to the injectors i would guess the high pressure part of the injection pump has froze from sitting.
If that is the IH282d with the Rosa Master pump, you probably have a stuck metering valve, which acts like a fuel shut off valve, in the pump. Some times a good tap with a rubber mallet will shake it loose and worse case is to go into the pump and do minor cleaning.I have an internal picture of the pump which I could e-mail to you if you want it. Contact me at [email protected] and can foward it to you.
Bob Ohio
Ac 21 is probably got you covred.. The injector pump is stuck in the off position on the inside. Like he said sometimes a tap will do it.But he will probably have to send you the photo. Not a big deal just the top of the pump to realease the thing. The only other thing is the pump drive is broken. You can take off the 2 little timing acces screws and watch as you turn the engine over and see if things are turning to check the drive shaft.
ACHD21A , would it be ok if I E mailed you too . I also have two D282's that have been sitting and am sure I will need to clean them .
Thanks Mike
Just read the post coffee Glad, to share the info, see you a lot on Red Power, I use IH915 up there. Have quite a bit of IH info on hand. all farm equipment here is IH. Bob Ohio
Ahh , now I see it . Thanks , a pic is worth a thousand words . If I can glean a tenth of the info on these websites I'd be a very happy man . Thanks to all who willingly share .
