Pat-CT
Im going to attempt to save a TD6 from the scraper.....i know it has one if not both steering clutches bad but im not all that concerned and i ahve seen the price of the clutch disks etc.... my concern is with the engine....are head gaskets available for these engines? i just want to get a idea for the inside of the engine and i want to take the head off first thing to see how bad its stuck if at all. any suggestions?
head gaskets sets are available, your looking at speeding 150 for the package. There really expensive engines to work on, i have over 3.5 grand into mine and it was running to start out with... Not to discourage you but i would look at parting it out if you do not know the condition of the engine, ie cracked head, block cracked, bad injector pump, injectors, pistons etc... Best advice is to get things checked and see if there soundness and go from there.
Andrew
The TD6 engine is the same as a MD engine. Thus it is, as Andrew points out, possible to get parts. I also agree with him that the actual condition of the engine, and for sure the under carrage/track pins and drive sprocket wear are manditory decision making issues. If very servicable, it could be fine. If it has a cable blade, or no accessories, it night not have much usability. It is too heavy to take to shows unless you are a lowboy trucker. Jim
