TE20 hydraulic arms lifting/lowering problems
crippss
Hello! I am hoping someone could shed some light for me. I have finished rebuilding the engine on my '53 TEA20. And now I'm onto the hydraulics.
The hydraulics work! However, they're either shooting up or dropping. There seems to be a spot where they'll either disappear into the ground or shoot up. This makes it frustrating while bush mowing!
I have a little device that goes on the lever to stop it at a certain point so the arms sit at a specific height. I took it off my second TE20.
I've read through a few manuals, but isn't something I've come across yet.
Thanks in advance!!
There is no position control per se on the TE/TO-20 or TO-30. There is a method called "Marlowe"s Methods" after a regular contributor to the Ferguson Forum who first described it. It can be found in the archives. Otherwise you have to use limiter chains to fix the mower at the desired height OR you can buy a "Fergie Limiter" or "Zane Thang" or make a feed back device to give your tractor position control. The directions for making a feedback device is also archived.
Awesome!!!! Super appreciate the response! Out here in my neck of the woods there's very little fergie related so getting questions answered and parts are hard to come across. I'll have to see what I can conjure up.
The chains (from what I can see) go from the rocker bracket to the end of the lift arms? Seems like a crude way of doing it!
I looked up the 'zane thang' and limiter, and as I'll only be bush mowing for a few days a year I don't think it's worth it, especially at the cost I can imagine it'd be for me here haha
(quoted from post at 20:12:40 06/10/17) Awesome!!!! Super appreciate the response! Out here in my neck of the woods there's very little fergie related so getting questions answered and parts are hard to come across. I'll have to see what I can conjure up.
I frequent this forum because I have a MF202, but I also have a Ford 8N. The 8N is my mowing tractor. It has position control which works perfectly as it should but I use limiter chains on my mower. I like the idea of the mower just hanging there on the chains instead of the position control having to work to keep in in place.
Back again because they won't let us edit a post here. I just wanted to say, there is nothing crude about using a set of limiter chains. They work perfectly.
Thank you for the comments. I have a good friend who has an
8N so I believe somewhere he's engrained the control limiting
into me haha. I'm only 25 so have a lot to learn about these
creatures!
