Hi Guys
I'm newbie to this fixing tractors business.
Anyways I have this 194? TE20 that I left it outside (bad decision) and it rained forever and when I used it a couple of times later and got stuck in gear and with a bit of gear lever wriggling came free. After shed storage I went to use it and again stuck in gear between 3/4. Reverse was free at this stage I pulled down the gear cover and found milky oil thanks to my negligence and found that the selector rods were stiff so with a drift got them moving again and the gear change was working.
Moving forward a few months I went to use it to pull a fallen tree and trundled to it, manoeuvred in place and backed up to get the chain on and there it happened would not move out of reverse with any wriggling, so I backed all the way the 300m to the shed and there she rests, funny how reverse was ok during this journey then suddenly not.
Just wondering if any of you seasoned Fergy guys have a suggestion on what I should do. Is it any drama to take the selector rods out and run an emery paper on dowel as another post says, is there a lubrication that will assist in keeping it free running or are we relying on splash back from the gearbox?
I don't like to tackle stuff without some knowledge, the gear box oil should have separated the water by now so I can drain the water off.
Perhaps there is another fault with the gears an earlier owner did some restoration work on it, that would be why there was no gasket between the gearbox and cover or the oil fill plug if there is even suppose to be one in those places.
Thankyou in advance
Wayne
Thankyou in advance
Wayne
