TE20 timing marks
ddfitch
Does the TE20 have timing marks stamped into the flywheel face like the TO30 does? I have looked and cannot find any
No the TE does not have marks on the flywheel. There is a timing punch mark on the pulley end of the Crankshaft. If memory is correct the book says to transfer these marks to the pulley and case so they can be seen.
I do not have my book in front of me so I may be off some.
Look on the right side of the Timing cover close to the Pulley, you will have to clean off all the dirt first. The marks are there but sometimes difficult to read with the Radiator blocking your view.Should be timed to exactly TDC if it has the original type Lucas Distributor, but not if you have any other type as it will be too far advanced..John
