Walt Dickie
I have a TEA 20-85. I acquired tractor last year and it started easy and ran with good oil pressure. I drained all fluids for winter.
I tried a compression check by spinning motor several times with the hand crank. Readings between 65-75 psi.
Question 1. Is this a reliable way of doing a compression test or do I have to turn the engine over with the starter motor or run it until it is hot??
Question 2 If this is a reliable test, what is acceptable compression??
Question 3. What is a "Wet Test"??
Thanks Walt
Thanks Walt
