TEA-20 Exhaust Cherry Red
oldfergie
I have a 1950 Ferguson TEA-20, and my exhaust turn cherry red when it run. Removed the muffler to make sure it was not stopped up, still the same. If anyone have any idea please help.
Late timing, as said, &/or mixture too lean.
Thanks, will take a look at the distributor tomorrow.[/quote]ate timing, as said, &/or mixture too lean.
I used a strobe light to check the advance on my TEA-20....
145 teeth on Ring Gear.....360/145 teeth = 2.48 deg / tooth...
My TEA-20 has NO TIMIMG MARKS on the flywheel..........????
With the Starter removed, I marked a tooth at TDC..
Pull started the Tractor....
Bob...
I had a farmall 706 gas years ago.
Pulling 4/16s at night the muffler would
glow dull red in the middle. Couldn't
see it in daylight. Normal if working
hard.
Dad had a WD and we ground ear corn with a Wetmore hammer mill. As a 14 year old boy shoveled corn through it and the
exhaust would get red with in half inch of the top. Years later talking to a farmer and and he said his neighbor only
plowed at night. He had WD 45's and if anything got red above the manifold you opened the load needle more.
Being that a gas engine at full load and depending how rich or lean . They run normally in the 1100-1300F range . No wonder the manifolds and muffler glows .
(quoted from post at 18:27:25 05/21/21) Distributor advance is stuck, not advancing timing with speed
as it should. VERY late ignition timing can cause it too.
Thank you for the information very helpful. Removed the distributor and found the advance frozen, had to used a lot of WD40 to get it free. Once freed and lubricated, reassembled and installed, cranked and run like a champ. Once again, thanks for the help.
