Hello all. Hope that you are all safe and staying healthy! I have a 1952 TEA 20(85) still positive ground, 10 yr old generator, voltage regulator, fan/generator belt & wiring. Up until recently it ran well and the charging system worked well. Just started it up with the battery at 11.6 volts. Runs well but is not charging the battery. The belt has about 1/2-3/4 of an inch deflection when pushed down so it appears to be correct. When it is running, the voltage at the battery is still 11.6 volts rather than 13-14 volts. The red ignition light remains on regardless of rpm (when charging properly it turned off as it should have when revs were up above idle). Any quick tests to determine if the generator or voltage regulator are malfunctioning? Any other test/suggestions to determine the problem? Thanks in advance for any tips or help. Ron
