Matt Higgins
Hi guys
Latest update is really an answering info from last week one really.
Bill wrote:
Hello Matt,
First of all. If I understand you correctly, you have got the engine running long enough to adjust the timing. This is not the way to do it.
The centrifugal weights starts to advance timing at very low speed, so when it idles the timing is advanced already. The way to do it is when the engine is stopped.
I will give you the correct procedure, but I need the engine number and distributor number.
The engine number is located above the oil filler cap, and a little forward.
Then, take a look at the numbers below.
Type 1:
Engine number S1E to S8995E
Distr. model D3A4
Distr. number 40132
Type 2:
Engine number S8996 and onwards
Distr. model D3A4
Distr. number 40146
Type 3:
Engine number S1E to S8996E
Distr. model D3A4
Distr. number 40146
Type 3 is actually a Type 1 engine with the type 2 distributor, as a Lucal Replacement distributor.
Please tell us what combination you have, type 1, 2, or 3.
I have a very strong feeling that you have too late timing. Both the sooting, bad running, and hot exhaust indicated this. In addition, setting the timing at idle speed will 100% sure fool you to believe you have a more advanced timing than you actually have. So, it is pretty many circumstantial evidences that you may have too late timing.
Best regards, Bill
So I've checked today, and the engine number is S31750E, and the Distributor is 40146D, which I'm deducing means we've got a type 2 engine. So if Bill's keeping a look about, the info you had would be gratefully received.
Only had an hour today to do any work on the ungrateful beast, tried the easi-start around the manifold and got a little bit of reaction, but it's running so lumpily that it wasn't really clear.
We've also found out that the clutch is bust (has no effect at all, nowhere near getting into any gear!), so we've got to split the tractor anyway, so I think we'll have the engine to bits again, put new gaskets all round and see if we missed anything the first time round.
Oh yes, and if Jerry's about, I've had a look for your artcile on timing but couldn't find it, if you would send it on, that would be great. No rush, as we've other things to be getting on with now, but it would be good for when we come to set it up again.
So a bit dispriting, but hey ho, it's only a tractor, can't let it get you down too much!!
Matt
Bill wrote:
Hello Matt,
Type 1:
Distr. model D3A4
Distr. number 40132
Type 2:
Distr. model D3A4
Distr. number 40146
Type 3:
Distr. model D3A4
Distr. number 40146
Best regards, Bill
Matt
