TEA20 Lube Specs
The rearend takes 6 gallons of GL1 gear oil. This is available in the States fron NAPA stores and is PN 65-205 for the 5 gallon jug.
You fill it through the plug that is near the shift lever. Be careful as you get near the end of filling as it takes a few minutes for the lube to level out with the dip stick at the rear and it is easy to over fill.
There is a rear end fluid changine procedure available if you want it let me know.
Jeff
