Tea20 Rocker Arm torque settings
Good day kaesark
Quote:
PostPosted: Tue Oct 05, 2021 1:40 pm Post subject: Tea20 Head Casket Reply to specific post Reply with quote
Hi
Having completed a full restore on my TEA20 I now have the slightest of water escaping back left corner of the cylinder head. I have not re torqued the head since restore so that will be first step. My question is should I have used a gasket sealant on the head casket????
Did you remove the head???
If so what did you find..??
Component NUMBERS that you require a Torque value for..?
Bob.
Hi
Bob I have re torqued the head and found that there was some slack in 2 head bolts.
Appears to have fixed the very slight water drop, so pleased I didn't have to go to go to next step and lift the head.
Now all I have to do is figure out my govener issue. I should have replaced it at time of reconditioning the engine.
