Did some checking of the rod bearings and rod journal size (this is the crankpin diameter I am assuming). Here is what I found on #1:
Rod journal sizes measured at various points:
2.084
2.085
Not sure if this is within tolerance, not sure what "clearance new" means.
Bearing thickness:
Fairly consistent at .0675
Appears to be the original bearings, some minor scoring, nothing major.
What do I do with these measurements? Obviously the bearings are worn by 5 thou. Is this enough to cause some low oil pressure and/or light knocking in the lower half of engine? Can I just replace the STND size bearings and be on my way since the crank is showing wear in the 1 thou range? Thanks!
2.084
2.085
Bearing thickness:
