Old post, but note to last post-er just above this
one/ it was explained about the reason I couldn't simply do that.
Reviving this because I am at the same crossroads with an 8 and an 11 HP Tecumseh again. This time I'm repowering a Troy bilt horse.
I have 2 different Tecumseh engines this time, same general model numbers/series as before. I acquired another snow king OHV Tecumseh 11 from a neighbor's shed and just bought a power washer with a dead pump and a good HM80.
This time both choices are good engines. Both start easy and run strong. The 11 has the right crank for the tiller but has no air filter housing (no snowblower engine I've ever had has had an air filter) and id have to cut the 2:1 extended cam off. The 8hp in this case has the wrong crank. But as a non snow engine has more appropriate throttle/ governor linkage and complete air filter assembly. Due to the configuration of the gas tank and the extra hardware of the OHV version looks too bulky to fit behind the guard on this tiller. The 8 seems like the better option, but opposite of the first time I went down this road when the 8 hp had the crank I needed.
With both engines having same bore and stroke, but the OHV having more moving parts I can't see it being 40% more powerful. Are they really?
The last time, I transplanted the 11 onto a machine that originally had an 8 but I never got to use it with the 8hp in running conditions so I can't compare them. This time I'm replacing a very tired 6hp so either will be a noticeable power increase vs what's on this machine now...
Maybe I can set the 6hp out in the middle of the backyard when it comes off and start it up when the mosquitoes are at their worst
