TED20 - compensating spring
jacka
Year 1952 TED20. Could someone tell me what is throttle rod's compensating spring size and all spring measurement's (stiffness, thickness, length).
Thank you...
http://fergusonenthusiasts.com/restoration%20helps/tech/Adjusting%20Throttle%20Linkage.pdf
It is very unlikely your cigar box will have the original spring, so find one that does the job best.
As far as your other post, see trucker's post replies above yours.
(quoted from post at 01:18:45 08/03/15) It is very unlikely your cigar box will have the original spring, so find one that does the job best.
Can you (or someone else) tell me, is original spring very stiff? Or loose?
(quoted from post at 07:12:08 08/03/15)
They don't ship in Finland... Could someone tell me original spring measurements? I want to know which my springs is nearest like original...
(quoted from post at 12:07:22 11/11/15)
You are forgetting about spring rate. Just because a spring is physically the same size doesn't mean it will have the same rate. Do you really want to save a few dollars and have a non functioning governor. That governor and springs is a balancing act. Do you not have an Agco dealer that you can buy a 181535M1 from? If not go here. It says the ship internationally.http://www.jackssmallengines.com/se...RID:11&q=181535M1&sa.x=54&sa.y=12
You are forgetting about spring rate. Just because a spring is physically the same size doesn't mean it will have the same rate. Do you really want to save a few dollars and have a non functioning governor. That governor and springs is a balancing act. Do you not have an Agco dealer that you can buy a 181535M1 from? If not go here. It says the ship internationally.http://www.jackssmallengines.com/se...RID:11&q=181535M1&sa.x=54&sa.y=12[/quote]img]https://i38.photobucket.com/albums/e117/Buikki/Ferguson%20TED20%20-%20jakopaa/20151111_201358_zpsvz0i13vm.jpg[/img][/URL]
Jason S. I bought a new original compensation spring... =)
Spring will arrive in about a 1 or 2 week.
Now I have a new original compensation spring... Looks like, that compensation spring must be just right for that all play correctly...
(quoted from post at 09:04:39 11/20/15)
You are correct. That's why I said it is part of a balancing act.
