Massey3518
Hi
A Ferguson 20 I have just bought has got the Hydraulics jammed in the full up position and won't go down. I've pulled the hydraulic cover off. Checked the hydraulic pump and it appears to be pumping oil.
The cross shaft and draft assembly are totally seized and took some amount of heat and bashing to dismantle.
I plan to renew the hydraulic piston rings and a new draft assembly and change the relief valve in the pump.
Apart from that is there anything else I should do or what would have caused this to happen?
Also on the PTO selector lever is there any oil seals in that side plate?
Can't see it mentioned in my manual.
