Tef 20 jerky hydraulics
Dano41
The tractor is completely restored but it was rarely started for a year and maybe the lift was never tried.I lifted a roughly four stone weight with the lift and it was still up over night.I have started it daily for about a month and tried the lift but it is still jerky.The oil level was at the low level and I topped it up.Any idea how I could fix preferably with out stripping her down again.
Jerky and slow lift is a symptom of bad pump valves.
Only solution is to pull the pump and go through it or get a remanufactured one.
I'm surprised it held itself up. Have you tried letting it down?
(quoted from post at 08:15:17 03/07/19) Jerky and slow lift is a symptom of bad pump valves.
The lift goes up and down lifting two people but is jerky.The pump was arleady done up,buying a reconditioned one?
I can't think of anything else that would cause jerky lift other than a pump problem.
The jerky I am referring to is typically severe enough to shake the whole tractor.
Since the pump is submerged I doubt it would be air. Bringing the RPM up should help, but it should be smooth even at idle.
Possibly a bad rebuild.
