Tekonsha brake controller
37 chief
I have my trailer off the ground, and trying to get the brakes to work. After I disconnected the rear axle wiring. The front axle brakes worked, Then the brakes stopped working. I could hear the magnet humming, but didn't have enough power to stop the wheel from turning by hand. I ran a separate ground from the truck to the trailer. That didn't seam to help. I guess the controllers are like everything else, they eventually fail. The controller is 15 years old. What am I missing? Stan
How are you activating the trailer brakes?
If it is a proportional controller, you will need to hold the truck brake and move the over ride lever to actuate the trailer brakes.
Test the voltage at the magnet leads. Chances are if you hear the magnet, there is a mechanical problem with the brake, not the controller.
Controllers rarely fail. It's almost always a wiring or mechanical issue.
Steve I have to respectfully disagree with that statement. I have sold and installed brake controls for over 40 years and I have replaced dozens and dozens of faulty controls. Some that wouldn't even work right out of the box. Bad wiring and shorted magnets will cause them to fail. Anything electrical can and will fail. I had one fail 250 miles from home pulling a loaded 48 ft 3 car hauler on a Saturday evening. I almost never found one to replace it. From that day on I always had a spare behind the seat. I do not sell Tekonsha. I have had more problems out of them than all the rest put together.
My brakes have two wires on each magnetic, so grounding the trailer isn't important.
My magnets measured 4 ohms. Four 4 ohms in parallel equals 1 ohm. So use a 12 battery and apply 12v voltages to brakes, you should measure about 12 amps. Pull trailer in yard and see which wheels lock up. That should tell you what brakes aren't working.
Rusty brakes may take some time to clean up rust. George
(quoted from post at 07:39:13 03/05/20) Steve I have to respectfully disagree with that statement. I have sold and installed brake controls for over 40 years and I have replaced dozens and dozens of faulty controls. Some that wouldn't even work right out of the box. Bad wiring and shorted magnets will cause them to fail. Anything electrical can and will fail. I had one fail 250 miles from home pulling a loaded 48 ft 3 car hauler on a Saturday evening. I almost never found one to replace it. From that day on I always had a spare behind the seat. I do not sell Tekonsha. I have had more problems out of them than all the rest put together.
I as well had one fail with a heavy loaded trailer.
Side of the road I wired in a toggle switch to bypass the controller and send full 12 volt to the brakes.
Was adequate to get me back home.
After I replaced the controller I left the Hail Mary switch in place just in case.
Here is another thing I did. I hooked 12 v directly to the coil. I heard the magnet humming, and I couldn't turn the drum. Through the controller, hardly any humming from the magnet, but it was getting current, and I could turn the wheel. Stan
