Temp gauge--- massey 245
I don"t know about your 245 but I have a 205 industrial and a 180 and neither one moves off the 130 degree mark unless the outside air temp is quite warm. I suspect that they don"t have a thermostat in them or if they do it is stuck open. I only use them in warm weather anyway so I never tried to change anything. Better cool than too hot.
I read your other post and it appears you "may" have shorted the Temp gauge. I guess it would depend on how large a spark was created. Most gauges will show full deflection when momentarily grounded, just make it "momentary". Also, did you blow either fuse on the dash when it shorted?
I have the temp guage out and if I run a wire from each post and touch it to the Batt it will jump all the way over. The tractor has been rewired and it has 2 in line fuses now and they did not blow. It does not have the diode that it calls for between the oil switch and regulator and it also doesn't have the 6 inch fusible link. I still cant get any power through the oil switch..... I think that is what got fried!! I would like to know it was right before I get another switch and fry it too!!!
Then the Temp gauge is ok...
The only way to check the oil switch, as I see it, is to have the engine running to provide oil pressure to complete the circuit. Odd thing, I have/use 2- MF 245"s with over 6000 hrs total and neither one has had the oil switch replaced, maybe I"m on borrowed time..
The only thing I have not checked would be the temp sending unit.......... any idea how to check it? You probably don't have much to worry about on your oil switch going bad unless you have a wire short out and have a small fire in the dash!!!!!
