I tried to check my coolant in my 60 last week, and found the level so low I couldn't draw any up in the tester. I deduced that the plug
was leaking, had not been evident parked on the gravel in my shed. So I drained out what remained of the coolant and flushed with a few
gallons of water, teflon taped the plug and put the 6 gallons of coolant I had caught back in. It appeared to be in good condition. It
came in the tractor when I bought it 2 years back. Now I've read someone's post here a while back that included a chart demonstrating
that you pick up a hp or two if you can maintain a working temp of about 195. I've only been able to achieve this in cool weather by
strapping a feed sack across the grille. My coolant tested good to -35F, which is way lower than we experience here in western NC. I want
to add more coolant, but also want to be able to get the operating temp higher. I don't understand how to adjust the shutters over the
radiator. Is that what I should be doing? And what mix should I use for the coolant to top off? Thanks for your advice.
