Terex 650B loader manual
Jonesreb
Hi all! New to the site and group. I have a Terex 650B loader that I have had for a few years but never had a repair manual for it. Some guy has one one eBay for $500 but at this point that might be more than the tractor is worth. I was wondering if there is a cheaper way to get one. I don’t see one list on this site unless it is under a different name. Any thoughts?
Charlie
Charlie
Welcome to the forums.
eBay has some and they are all north of $400.
You can find a Terex dealer and see what they can get and a price.
These were sold by agco Massey dealers
Because terex bought Fermec so Fermec manual would be same thing they did not change anything but color and name tractor was identical
So maybe try and look for Fermec manual
he couldn't do it if you need certain specs or something let me know I can get the info
I am heading over there Monday to get some parts so let me know will look while I am there also
Thanks. I would sure appreciate the info. There are two main things I need to know. One is how to replace the fuel pump and the other is how to replace the fan belt. The fan belt seems like it should be simple but there is a shaft that goes through the fan belt and under the radiator. So it seems like I would have to either pull the radiator and quite a bit of other stuff or pull the motor. Neither one looks like any fun. Instead, for the interim, I have purchased a segmented fan belt that you take apart, remove the segments you don't need and put it back together. This allows me to get around that shaft. The belt keeps stretching a bit over time, so I have to keep tightening it a bit every so often. It needs a new alternator as well but I know how to replace that.
This is what the serial number plate says on the Perkins engine:
Perkins Engine
5616/2200
AQ31421*U278727J
Anyone know what those numbers mean?
Charlie
