Testing 6 volt genny
grandpa Love
Is it possible to bench test a 6 volt
generator? This is off a cub. Is the
generator from a farmall H the same?
Very simple to rebuild while you have ut off, Find a set of bushes, clean up the stator. Power wire brush, primer and paint the case and go. I did my first one off my 47 Ford when I was 14.
The motor test. Using a 6v battery, clamp a red jumper cable to the mounting frame (clean and shiny) connect the other Black cable to the ARM "A" terminal. Then find a good small jumper and connect it to the F terminal. Connect the battery Red terminal to the positive bat terminal. Then (while holding the gen down or in a vise) connect the black terminal. The generator should now easily start acting like a motor with the pulley turning nicely. Now connect the jumper from F terminal to Ground on the frame, or the grounded jumper clamp. the rotation of the generator pulley shuld slow down, but not stop. This proves the field is OK. Jim
John t has a real good procure. Maybe he will post it again or might be able to search the site.i have it printed off but its at the other farm in the shop.
