testing compression on diesel engine?
Anonymous-0
Hey folks,
was just looking at compression testers on the web. It shows a different set for diesel motors. Can someone tell me how to check on my diesel tractor?
Thanks, Dave
You need a tester with the appropriate adapter to fit either the glowplug hole or the injector hole in the cylinder head of your particular engine.
Now see Dave that is one where you have to be smarter then what your working on to know how to do that. Or you can do as Bob says since he has now got you smarter that is. LOL Ya I have to give you a hard time once in a while since I know you like to do it to me. Oh by the way be careful when checking compression on a diesel and be sure you have the correct gauge when doing so. Funny how you can really mess up a compression gauge if you do not have the correct one for a diesel
On Detroit Diesel two-cycle engines, the compression tester was installed instead of the fuel injector for the cylinder in question, and the test was done with the engine running.
Usually, we would touch the exhaust manifold with the engine running to look for a cold cylinder so as not to have to test each and every cylinder.
I don't ever remember doing a cranking speed compression test on any make Diesel (hard on the starter).
The specifications were listed in the service manual for the model being tested.
you might want to google LEAK DOWN TEST as i understand that a diesel compression test is a thing of the past
