Testing fluorescent tubes
coshoo
Anybody know of a way to test fluorescent tubes? Other than switch-and-try? These are 8 foot HO tubes in my shop, at over 10 bucks a pop. The ceiling seems to be getting higher and the ladder ricketier in
my advancing years, and I'd like to limit my trips up there.
There are testers that will tell if it's the lamp or ballast.
Never tried one, quite expensive.
This was a cheap one, don't know if it will work.
But what I've found, when HO lamps start getting weak, they won't come on. Or maybe delay, come on after a while. Cold and high humidity make them worse.
Lamp Tester
Simple is look at the ends of the tubes. Are they getting all smoked up inside? Usually means change me time. There is a guy that shows up at a couple of car shows in my area and two flea markets. He sells twin four foot LED fixtures for $20.oo each. They are fantastic and are daylite color. Same in the store go for 40 each. I have purchased six of them already and get an even beter price. Here is his phone number and he ships them. Very nice guy. Matt.
I am switching to no ballast LED tubes. Bought a 12 pack at Lowes a year or so ago and replace them little at a time. One 18 watt LED bulb is equal to two 40 watt fluorescent bulbs. The fixture probably needs to be rewired for the LED and then you need to make sure to mark it so wired so you or someone else won't install a fluorescent in the future. Wonder what that would do if a fluorescent got a 120v zap to one end of the tube?
