Thanks Jeffcat and Nobite
Hay hay hay
I wanted to treat the wood sides and floor of my manure spreaders. I was looking for an easier method than a brush and roller. I found your recommendation in the archives. I went to Harbor Freight and bought an "Abrasive Blast Gun" based on your recommendations. I works like a charm, fast, easy, cheap and clean. Thanks
Now how about an easy way to fix my dozen half full paint spray cans that no longer work?????
That's an easy one !
Take a tubeless tyre valve , remove the core and hold it over the nozzle tube of the can once you have removed the spray head . Connect a tyre inflator to the valve body , use a compressor to put in 2 or 3 PSI into the can , be careful not to over pressurise .
As long as the nozzle tube is not full of dried paint the can will have more than enough gas to allow you to use what's left . Works a treat on WD40 and the like as well . Only draw back is that the air will ruin the paint over time so try to use all the can soon after you've re gassed it .
