That's gonna leave a mark!
Royse
My sister ran her mower deck into the ground.
First picture is the "new" all the way up position on cement.
The other two are with the deck removed, setting on the garage floor.
Are ya sure she's not MY sister???
Because I really feel she and I might be
related... does she tear caburetors off
of Cub Cadets using a swingset? LOL!
If that's a Wheel Horse the decks for the C series and newer were still available from TORO as well as the shell a couple of years ago. Not cheap though.
Rick
Rick, it's a 44 inch deck on a Toro ZTR. New is available. ~$2000
A complete, used, ZTR mower is less than that around here.
Including this one when I bought it 4 or 5 years ago for $1250.
JD720, the rust was definitely there, but there was no hole until it
got bent like this. It tore open when it hit the ground and bent.
I have a torch, a welder and a press. I'll see what I can do to limp
it along until I can find a used deck or a replacement mower.
I had a toro z commercial mower, it had a stamped
deck, I went to exmark, I like the welded fabricated
decks much better.,
You can see the steel around the bottom of the
deck, makes a big difference.
You can't kill a Wheel Horse deck! I'm still trying to wear out a 1969 48 inch deck. Got a rebuilt back up rearing to go just in case.
JayinNY, your Exmark and my Toro commercial are nearly identical.
Fabbed deck, pulleys, springs and probably more, even share
the same part numbers. I have bought quite a few replacement
parts that fit both. They were probably made by the same company.
The stamped "tin", bent deck I pictured is off a Toro "TimeCutter".
It is the homeowner version, not commercial.
Totally different machine from yours or my own.
A much cheaper version like one would buy in a box store.
Way smaller tires, no suspension, Briggs and Stratton engine, etc.
I bet she feels bad- but is it her fault? It looks to me like the little roller wheel on the front of the deck isn't close enough to the end of the deck- it didn't do its job. Some needs to give her a hug.
It looks to me like it would have just ridden up and over if it still had a little strength to it.
You guys got it all wrong, again!. That's designed that way on purpose, for the citiots who mow their lawn every other day whether it needs it or not (it usually does thanks to 100 pounds of N per square foot per month applied). This feature allows the corner of the deck to turn up a little furrow in the sod, kinda like a marker arm on a planter or drill, so you can actually tell where you should make the next pass when removing 1/8" or less. Those of us who mow the lawn only when prompted by local officials or due to the loss of pets/small children in the tall grass rarely need this deluxe feature.
K ..... "citiots" .... a rather childish reply. Do you think it possible to reply without name calling and making yourself
look like a fool ???
We see how ignorant people from the city are around hear all the time, and they try to tell us how we should conduct our lives. That doesn't cut the mustard in my book. "When in Rome-Do as the Roman's do".!!!--------Loren
Well Case Guy, I'm sure a lot of city folk would be heard saying similar comments about country people, but my comment had nothing to do with that really. Obviously you missed the point of my reply (which is obvious from your use of the Rome/Romans quote). It had to do with senseless and childish name calling like one might see in a school yard. For example, I would never call anyone an idiot because they made a spelling error in their reply (like you did), but some people might.
(quoted from post at 09:10:16 05/30/19) K ..... "citiots" .... a rather childish reply. Do you think it possible to reply without name calling and making yourself
ade me smile :lol:
but you didn't :evil:
(quoted from post at 14:13:09 05/30/19) We see how ignorant people from the city are around hear all the time, and they try to tell us how we should conduct our lives. That doesn't cut the mustard in my book. "When in Rome-Do as the Roman's do".!!!--------Loren
And the same goes when in Utica or Syracuse!
Garry
