JOHN HUNT
the draft on hyd I put to the lever top and sometime it won't lift. sometime then it bound up and fall back down.. what goin there. I only lifting about 250 tro 300 pound on the 3 pt lift
John.......besides seeing the no-no blue RTV sealant, yer little "flush" handle is pointing straight DOWN. It should either point straight UP (for position control) or straight FORWARD (draft for plowing). All the pictures in the world ain't no substitute for VISUAL inspection of INSIDE yer top-cover mechanism. 'sumptin' WRONG and I ain't gotts X-RAY vision........respectfully, Dell
when lever go to the top that when act up, the pump work fine. when stop the tractor the three pt stay up for 3 or 4 day...
but when use the draft that when happen and it 52 8n tractor
What I'm saying is that that little 3" handle should point straight up, or straight horzontal.. not straight down.
soundguy
no-no blue RTV sealant, what do you mean there, I use permatex on the top gasket the blue you see is ford blue color it has 3 or 4 didffent color even mf yellow too.
That top cover needs the OEM paper gasket.. not gasket goo.. not even permatex.
And what Dell said.. that little handle shoul dbe pointed straight up.. or be parallel tot he lift cover.. yours is pointing straight DOWN.. that ain't right.
soundguy
Either his handle is on backwards, or mine is one.
On mine the angle on the handle goes to the inside, and would hit the lift cover before going past the forward position, and into the down position like his is doing.
The way his handle is pointed right now, if the pin were removed, and the handle flipped to the top inside, and the pin replaced it would be like mine in position control.
Then it would push to the front, horizontal position for draft control.
The way it is currently installed to be at that position, it would have to be flipped to a rearward position, which can't be done, due to the quadrant being in the way.
That is what appears to me to be his problem.
I hope that made some kind of sense.
The Handel can b installed wrong,,, if so he would only have position mode,,, NO DRAFT MODE,,, the shaft Threw the cover can only B installed one way,,, if the pin is not sheered sum'n broke inside the lift cover,,, either way the lift should at least werk,,, time to go fish'n
I think John had a loader,,, I have seen one loader tractor were the shaft froze up on the lift controls,,, I spec cuzz with a loader the lift is not used much,,,, its also notable that the lift and lift arms are usually in good condition on a loader tractor,,, the lift just does not git hammered like one with out a loader,,, the loader does all the werk,,, the lift is pretty much useless with a loader
