Caroline Chamblin
Hi Folks,
Can someone explain why it is easier to shift the transmission when the PTO is not engaged? Sometimes I take the PTO out of gear to be able to shift then re-engage it to mow. This is mostly switching between reverse and first gear. I still don't have the carb exactly right but it is mowing. The ammeter still goes to negative voltage after turning off, at least until I tap the cut-off switch with the screwdriver handle. 6 volt system with round can distributor modification.
thanks,
Caroline
thanks,
Caroline
