THE SERIAL NUMBER APPEARS LIKE BELOW
Columbus
660
55686
I can't seem to determine what this means. We had to scrape off layers of paint, so did we not get the full serial number? We were trying to determine its exact year and model. Thank you for you help.
If meaning a international 660 the serial numbers didn't go that high. Same for a international 460. Farmall 560 did have a serial number in that range in 62.
Hello Columbus welcome to YT! Looks like you roused
a couple smarties, however even though you yelled at
us about your serial number ..all caps.. we still cannot
get a clue about what brand your tractor is. It could be
an IH 660, but the serial numbers should be in the mid
7000s or lower. If is an Oliver it should have a serial
number higher than 73132. Beyond that I am out of
options, brand or at least a color.
I apologize if my CAPS were on. The software I use at work requires capitals and I didn't even think of that. Sorry.
If you on the classic view go to the left under research & info then serial number then ford then the 600 series you can figure out where your number fits in. I looked and yes it fits in so do the math.
(quoted from post at 07:56:06 07/07/22) Ha! Ha1 It is an approximately 1954 Ford Tractor. Sorry if my question seemed so wrong.
Not wrong. Just lacking context.
Easy to forget when you're looking at the tractor, that we can't see it and all we have to go on is what you wrote.
Two plain old unformatted numbers just isn't enough information.
