thomas-450 charge pump
put new seals and o rings in pump and it is now pumping-YEAAAAAA-thanks to all who offered advice-i will dance at your next wedding if you are that dumb-thomas
i noticed that pump turned freely with no resistance before reseal-after i put new o rings and new seal it took considerable force to turn pump.
tmoore 45 acp did your pump shaft have any wear where the seal run? My shaft had groove where the seal run that might be my trouble and I can not find the gears any where. I might be able to fill the groove with something its just the with of the seal lip. I am glad you are going again. Thomas
tmoore yes I put the orings behind the front bearings. I have not tryed it again since last post may in a day or two. Thanks Thomas
